Answer: I’m using grafana 7.5.15 on centos8 -
Answer: I’m trying visualise my data’s elasticsearch on grafana -
Answer:I’m using Logstash+elasticsearch they are already configured and running. I just need to export the data to grafana. But all the tutorials I’ve seen, it’s not working.
what version of elastic search?
I’m using elasticsearch 8.6.2
In grafana Have you added a data source using elasticsearch plugin that points to your elasric search?
yes , but get this error: Elasticsearch error: 400 Bad Request and other error: Elasticsearch error: Types cannot be provided in get mapping requests, unless include_type_name is set to true.
What if you select raw data option
it says i don’t have any data
can you change you filter to span more than 7 days?
Another way to debug is via kibana.
do you have kibana for it? if so search the index you use for grafana to find date range
I know, just that I need to use grafana
