apal
June 10, 2022, 9:19am
1
Hi Team,
I am integrating K6 cloud to Jenkins pipeline. I am not a root user and not having sudo permission. So when i execute the k6 cloud i got below exception.
k6 login cloud --token xxx
time=“2022-06-09T14:17:05Z” level=error msg=“mkdir /.config: permission denied”
Already running K6 container with default jenkins userid 1000. I saw we can change the path of config file. Can anybody help to resolve this issue?
Regards,
Amit
Hi @apal ,
you can use as a better alternative the K6_CLOUD_TOKEN environment variable.
You should set the variable from Jenkins so the command will end in something like the following example:
$ K6_CLOUD_TOKEN=<YOUR_K6_CLOUD_API_TOKEN> k6 cloud script.js
Let me know if it helps.
apal
June 15, 2022, 11:55am
5
Hi @codebien ,
I was able to resolve the issue with --config option. Thank you for responding.
Regards,
Amit
