Interested in using Grafana to generate SNMP traps
I am interested in using Grafana’s alert-notification capabilities to generate SNMP traps, and I’m wondering if anyone else in the Grafana community has done something similar. I know that SNMP is not supported as an alerting engine out of the box.
Is there a plugin that allows SNMP traps to be generated as an alerting mechanism? If not, would it be possible to create one?
Alternatively, is there a tool that is the consensus choice for taking in Grafana alerts (via webhook or maybe kafka) and generating SNMP traps based on that?
Any advice would be appreciated, thanks!
Would also like this, if any creative solutions already exist, I would also appreciate a heads-up.
I also want the same thing. Is there any solution for that? I wanted to create a notification for ISIS adjacency state whether it is up or down. I found MIB for that but not able to get alerts or notification for that. please help me out from this.
We can do custom snmp trap relay for grafans
