Is there any way I can convert my XML script files from jmeter to k6 format?
Check out the jmeter-to-k6
converter at GitHub - grafana/jmeter-to-k6: Converts JMeter .jmx files to k6 JS code
Here’s the command you can run to create k6 script from your jmx file.
node bin/jmeter-to-k6.js your_jmeter_file.jmx > converted_k6_script.js
