I monitor several machines via Icinga and have set up a Grafana dashboard for each machine using InfluxDB with Flux language as data source. For Grafana, I use the current version of the Docker Container.
My question now is whether I can create a panel so that I can directly see in only this one whether any metric exceeds its limits or not? And what would be the best way to implement this? The goal is to have a dashboard where all these “master panels” are, so that you can see directly which machine is causing problems.
Hi, I am relatively new to Influx. How exactly do I get the scheme? InfluxDB is also running in a Docker container and when I use the API (as described here Manage bucket schemas in InfluxDB | InfluxDB Cloud (TSM) Documentation), for example, I only get error “404 page not found” as a response.
