This config is working, but it seems strange to me.
Also it’s nowhere documented that it can work like that.
Here I have a scraping config and before starting the pipeline_stages
, I relabel the kubernetes tags.
If I don’t relabel before, the pipeline_stages
won’t work.
Is there a better way to do this?
promtail:
enabled: true
serviceMonitor:
enabled: true
config:
lokiAddress: http://monitoring-loki:3100/loki/api/v1/push
snippets:
scrapeConfigs: |
- job_name: kubernetes-pods-app
kubernetes_sd_configs:
- role: pod
relabel_configs:
- source_labels:
- __meta_kubernetes_pod_controller_name
regex: ([0-9a-z-.]+?)(-[0-9a-f]{8,10})?
action: replace
target_label: __tmp_controller_name
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_name
- __tmp_controller_name
- __meta_kubernetes_pod_name
regex: ^;*([^;]+)(;.*)?$
action: replace
target_label: app
- source_labels:
- __meta_kubernetes_pod_label_app_kubernetes_io_component
- __meta_kubernetes_pod_label_component
action: replace
target_label: component
- action: replace
source_labels:
- __meta_kubernetes_pod_node_name
target_label: node_name
- action: replace
source_labels:
- __meta_kubernetes_namespace
target_label: namespace
- action: replace
replacement: $1
separator: /
source_labels:
- namespace
- app
target_label: job
- action: replace
source_labels:
target_label: pod
- action: replace
source_labels:
- __meta_kubernetes_pod_container_name
target_label: container
- action: replace
replacement: /var/log/pods/*$1/*.log
separator: /
source_labels:
- __meta_kubernetes_pod_uid
target_label: __path__
- action: replace
regex: true/(.*)
separator: /
source_labels:
- __meta_kubernetes_pod_annotationpresent_kubernetes_io_config_hash
- __meta_kubernetes_pod_annotation_kubernetes_io_config_hash
pipeline_stages:
- match:
selector: '{app="server"}'
stages:
- cri: {}
- logfmt:
mapping:
level: level
logger: logger
time: time
msg: msg
- timestamp:
source: time
format: RFC3339Nano
