Issue after installation of grafana
I have an issue occurs after installation,
Could not communicate with your OnCall API at http://engine:80. Validate that the URL is correct, your OnCall API is running, and that it is accessible from your Grafana instance
Please help
Hi @ahmed89,
Welcome to the :grafana: community support forums !! :slight_smile:
Can you please tell us how you installed Grafana OnCall (i.e. which documentation you followed)?
Also, did you install OnCall cloud OR OnCall OSS?
I am using grafana OSS and still facing the same issue i followed the documentation where we install via HELM chart .
