Grafana version:
Helm chart version 6.56.1
Run Grafana in HTTPS inside a k8s cluster behind an Nginx Ingress Controller with a self signed certificate. -
Grafana helm values:
grafana:
replicas: 3
resources:
limits:
cpu: 4000m
memory: 8Gi
requests:
cpu: 1000m
memory: 4Gi
enabled: true
env:
GF_DATABASE_TYPE: mysql
GF_DATABASE_HOST: [redacted]
GF_DATABASE_NAME: [redacted]
GF_DATABASE_USER: [redacted]
GF_DATABASE_PASSWORD: [redacted]
GF_AUTH_GENERIC_OAUTH_EMAIL_ATTRIBUTE_NAME: mail:primary
GF_AUTH_GENERIC_OAUTH_EMAIL_ATTRIBUTE_PATH: mail
grafana.ini:
server:
domain: "grafana.[domain2].com"
root_url: "https://grafana.[domain2].com"
live:
max_connections: 0
auth.generic_oauth:
icon: signin
enabled: true
allow_sign_up: true
auto_login: false
client_id: [redacted]
client_secret: [redacted]
scopes: [redacted]
empty_scopes: false
auth_url: [redacted]
token_url: [redacted]
api_url: [redacted]
tls_skip_verify_insecure: true
Nginx ingress controller ingress
(we have two domains, domain1 directly points to the ip of our load balancer while domain2 points to domain1, inside the grafana “root_url” and “domain” config variables we have domain2):
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
namespace: monitoring
annotations:
nginx.org/client-max-body-size: "200m"
nginx.org/client-proxy-body-size: "200m"
nginx.org/proxy-read-timeout: "36000"
nginx.org/nginx.orgproxy-send-timeout: "36000"
nginx.org/server-snippets: |
location /api/live {
proxy_http_version 1.1;
proxy_set_header Connection "Upgrade";
proxy_set_header Host $http_host;
proxy_pass http://grafana;
spec:
ingressClassName: nginx
tls:
- hosts:
- grafana.[domain1].com
- grafana.[domain2].com
rules:
- host: grafana.[domain2].com
http:
paths:
- path: /
pathType: ImplementationSpecific
backend:
service:
port:
number: 80
- host: grafana.[domain1].com
http:
paths:
- path: /
backend:
service:
port:
number: 80
Nginx ingress controller values:
controller:
replicaCount: 3
service:
annotations:
service.beta.kubernetes.io/oci-load-balancer-internal: "true"
service.beta.kubernetes.io/oci-load-balancer-shape: "flexible"
service.beta.kubernetes.io/oci-load-balancer-shape-flex-min: 100
service.beta.kubernetes.io/oci-load-balancer-shape-flex-max: 100
enableSnippets: true
config:
client-body-buffer-size: 32k
ssl-buffer-size: 32k
large-client-header-buffers: 8 64k
proxy-body-size: 100m
proxy-buffer-size: 32k
- What happened?
When using Grafana on any browser sometimes a “NetworkError when attempting to fetch resource.” or “Failed to Fetch” error pop up shows up and the dashboard metrics disappear for a few seconds before reappearing, there’s no holes in the metrics and it’s been verified that it’s not a datasource problem.
For example in Firefox checking the console I see this when it happens:
runRequest.catchError {"data":{"message":"Unexpected error"}}
While in the Network tab I see that queries fail with this error:
NS_ERROR_GENERATE_FAILURE(NS_ERROR_MODULE_SECURITY, MOZILLA_PKIX_ERROR_SELF_SIGNED_CERT)
I did accept the certificate when opening Grafana on my browser, and this error seems to appear only from time to time and not always.
I disabled Grafana live because I saw that the browsers would refuse to accept the self signed certificate used for the websocket. So I was expecting to stop seeing this error now, but it keeps happening
I do not see errors in the Grafana log when these popups show up.
Is there anything else that needs to be configured in a Nginx Ingress Controller for Grafana in HTTPS? There shouldn’t be the need without Grafana live no?
