Hello Community ,
Issue on Grafana 6.*
We are working with the last version of Helm chart Grafana and I don’t find the way to configure repeating panels and Repeating Rows (Variable syntax | Grafana documentation)
Example
I have the same issue on the last grafana docker images:
- Grafana v6.7.1
- Grafana v6.6.0
On Grafana 5.4.5
I seems I work with repeating on Grafana v5.4.5
Questions
- Is there a way to add and edit repeating objects on Grafana 6.*?
- if not Is it planned to have this key feature of dashboard on Grafana 6.*?
- It is possible to edit dashboard from G.6.7.1 in G.5.4.5 as workaround (what could contains element not available on G.5, like ‘Logs’)?
Thank you in advance for your help,
Laurent
