I’m having trouble finding a way to link two different data types for the purpose of labels.
For example, I have an influx time-series with all the measurements i want, but that data has device IDs and no other identifying data like customer id, location, etc.
I have a second data source, which I’m testing google sheets, mysql, anything I can to try to bring this in, that has the device id as well as the other ‘missing’ data in columns.
I want to do a classic join, ie join on datasource1.device_id = datasource2.device_id so I can then get those labels into charts as well as use variables to filter on. So I can have ‘customer’ and ‘location’ variables and put those into teh query on /^$Customer$/ and /^$Location$/ for example.
The details/labels isn’t time series, so I can’t join on time with an ‘outer join’ transform.
yeah, so just top copy your example:
influx
timestame, device-id temp,humidity
2022-07-12, SN12345 75, 50
and the mysql data
Device-Id, Device-Name, Customer-Id
SN12345, Office-Temp-Probe, JoesIceCream
and what i’d like to have is Device-Name and Customer-Id available in Influx for variables and charts. So a variable might pull the Customer-Id list so it’s there for filtering, but then of course I need that value within the query so I can put a where in there to match it.
Any ideas yet? I need to do the exact same thing. I have a time series query result from postgress that has device ids. I want to join it with the device_id <-> device_name info that is in a Google Sheet. How can I do the ‘join’ and use the device_name in the legend of my time series graph, (instead of device_id)?
