Hi Team,
I’m working with K6 and want to know if there are any specific best practices or JavaScript standards that help us better maintain the project.
Hi Team,
Hi @Gerard,
I have a few of them in base of my experience:
Hope it helps
Greetings.
Gino
Thanks @Gino
Any suggestions on the JavaScript side?
You can take a look at these k6 templates for examples of highly modularized scripts using different libraries.
A set up like this could help you mix and match test logic, set logic dynamically through environment variables, et cetera.
