K6 not sending http headers correctly
Hi I am having the following k6 code .
import http from ‘k6/http’;
export const paramsHighPriority = {
headers: {
‘3gpp-Sbi-Message-Priority’: 10
export const paramsLowPriority = {
headers: {
‘3gpp-Sbi-Message-Priority’: 25
export const options = {
discardResponseBodies: true,
scenarios: {
lowPriority: {
executor: ‘constant-vus’,
exec: ‘lowPriority’,
startTime: ‘0s’,
vus: 5,
duration: ‘3s’,
highPriority: {
exec: ‘highPriority’,
startTime: ‘0s’,
vus: 5,
duration: ‘3s’,
export function lowPriority() {
http.get(‘http://10.96.36.153:80/SccTestService/v1/id’, { headers:{ ‘3gpp-sbi-message-priority’: 10}});
export function highPriority() {
http.get(‘http://10.96.36.153:80/SccTestService/v1/id’);
however i could see the header 3gpp-sbi-message-priority is dropped
please advise on this thank you
I think this is just an issue with single quotes and you need double;
I hope this solves the issue for you;
import http from 'k6/http';
  headers: {
    "3gpp-Sbi-Message-Priority": 10
  headers: {
    "3gpp-Sbi-Message-Priority": 25
  scenarios: {
    lowPriority: {
      executor: 'constant-vus',
      exec: 'lowPriority',
      startTime: '0s',
      vus: 5,
      duration: '3s',
    highPriority: {
      exec: 'highPriority',
      startTime: '0s',
      vus: 5,
      duration: '3s',
  http.get('http://10.96.36.153:80/SccTestService/v1/id', { headers: { "3gpp-Sbi-Message-Priority": 10 }});
  http.get('http://10.96.36.153:80/SccTestService/v1/id');
Hi @Prasanth. How can you tell the 3gpp-sbi-message-priority header is dropped?
I just did some testing locally (see attached screenshot) with your script and everything seems to work fine on my end.
Try running your test with the --http-debug="full" (i.e: k6 run k.js --http-debug="full") flag and monitor requests to check whether the header is being sent or no.
thank you it works .
