Hi
I have a grafana server on which I would like to perform load test on it,
in the setup()
, I would like to make an API call to the grafana’s API endpoint to create a viewer token, then in the default
function, I would like to send requests to the grafana server using the API generated in the previous steps, here is my piece of code:
export function setup() {
const url = 'https://grafana.domain';
const params = {
headers: {
'Authorization': 'Bearer AAA',
'Accept': 'application/json',
'Content-Type': 'application/json',
const payload = JSON.stringify({
role: 'Viewer',
secondsToLive: 1200,
const tmptoken = http.post(`${url}/api/auth/keys`, payload, params);
return {tokendata:tmptoken.json() };
But when I run k6 run --http-debug=full script.js
, I get the below error:
INFO[0000] Request:
POST /api/auth/keys HTTP/1.1
Host: grafana.domain
User-Agent: k6/0.37.0 (https://k6.io/)
Content-Length: 53
Accept: application/json
Authorization: Bearer AAA
Content-Type: application/json
Accept-Encoding: gzip
{"name":"dNN7Q","role":"Viewer","secondsToLive":1200} group="::setup" iter=0 request_id=5c828d3b-6380-48d3-51f0-ab773589f8f7 source=http-debug vu=0
Run [======================================] setup()
default [--------------------------------------]
ERRO[0063] setup() execution timed out after 60 seconds hint="You can increase the time limit via the setupTimeout option"
But when I send this request using CURL
everything works as expected:
curl --request POST -H 'Authorization: Bearer AAA' -H 'Content-Type: application/json' -H 'Accept: application/json' https://grafana.domain/api/auth/keys -d '{"name":"dNN7Q","role":"Viewer","secondsToLive":1200}'
{"id":17,"name":"dNN7Q","key":"BBB"}
