L SingleStat Panel not repeating based on variable
Created a SingleStat Panel in a dashboard to repeat the machine names and to show the status of each machine. WMI Exporter is used to gather system info. Only the first instance is shown and the panel is not repeating itself. Please advise if more information is needed.
Query Used
avg(wmi_service_state{instance=~"$Machine", name=~“amp.|merc.|zyt.|im.”,state=“running”})
Following is the JSON
“datasource”: “Prometheus”,
“fieldConfig”: {
“defaults”: {
“custom”: {},
“thresholds”: {
“mode”: “absolute”,
“steps”: [
“color”: “green”,
“value”: null
“color”: “red”,
“value”: 80
“mappings”: []
“overrides”: []
“gridPos”: {
“h”: 3,
“w”: 24,
“x”: 0,
“y”: 25
“id”: 104,
“options”: {
“reduceOptions”: {
“values”: false,
“calcs”: [
“mean”
“orientation”: “auto”,
“colorMode”: “value”,
“graphMode”: “area”,
“justifyMode”: “auto”
“pluginVersion”: “7.0.2”,
“repeat”: “Machine”,
“targets”: [
“expr”: “avg(wmi_service_state{instance=~”$Machine", name=~“amp.|merc.|zyt.|im.”,state=“running”})",
“format”: “table”,
“interval”: “”,
“legendFormat”: “”,
“refId”: “A”
“timeFrom”: null,
“timeShift”: null,
“title”: “$Machine”,
“type”: “stat”,
“scopedVars”: {
“Machine”: {
“text”: “gva-p-ict-03”,
“value”: “gva-p-ict-03”,
“selected”: true
Can you share your variable configuration? Do you successfully retrieve all variable values?
Thank you and please find the needed information…
Variable Configuration
Data Details
Object
request:Object
url:“api/tsdb/query”
method:“POST”
data:Object
to:“1593591996175”
queries:Array[10]
response:Object
results:Object
A:Object
refId:“A”
meta:Object
series:null
tables:Array[1]
dataframes:null
B:Object
refId:“B”
meta:Object
series:null
tables:Array[1]
dataframes:null
C:Object
refId:“C”
meta:Object
series:null
tables:Array[1]
dataframes:null
D:Object
refId:“D”
meta:Object
series:null
tables:Array[1]
dataframes:null
E:Object
refId:“E”
meta:Object
series:null
tables:Array[1]
dataframes:null
F:Object
refId:“F”
meta:Object
series:null
tables:Array[1]
dataframes:null
G:Object
refId:“G”
meta:Object
series:null
tables:Array[1]
dataframes:null
H:Object
refId:“H”
meta:Object
series:null
tables:Array[1]
dataframes:null
I:Object
refId:“I”
meta:Object
series:null
tables:Array[1]
dataframes:null
J:Object
refId:“J”
meta:Object
series:null
tables:Array[1]
dataframes:null
