LDAP Authentication not working with Grafana for poxisGroup
Hi Team,
I have integrated my LDAP with Grafana for Authentication.
I have defined and mapped the ldap groups in ldap.toml file but I am getting mapped to viewer group by default.
Below is my settings in the file :-1:
## Group search filter, to retrieve the groups of which the user is a member (only set if memberOf attribute is not available)
group_search_filter = "(&(objectClass=posixGroup)(memberUid=%s))"
## An array of the base DNs to search through for groups. Typically uses ou=groups
group_search_base_dns = ["ou=Groups,dc=example,dc=com"]
# Specify names of the ldap attributes your ldap uses
[servers.attributes]
name = "givenName"
surname = "sn"
username = "cn"
member_of = "cn"
email =  "email"
# Map ldap groups to grafana org roles
[[servers.group_mappings]]
group_dn = "admin"
org_role = "Admin"
# The Grafana organization database id, optional, if left out the default org (id 1) will be used
# org_id = 1
group_dn = "developer"
org_role = "Editor"
# If you want to match all (or no ldap groups) then you can use wildcard
group_dn = "*"
org_role = "Viewer"
Logs : -
t=2018-05-18T02:27:51+0000 lvl=info msg="Searching for user's groups" logger=ldap filter="(&(objectClass=posixGroup)(memberUid=test))"
Any help ?
Your group_dn settings in the [[servers.group_mappings]] entries should be the full dn of each group you want to map, eg instead of "admin" you would use "dn=admin,ou=Groups,dc=example,dc=com" (assuming your group_search_base_dns setting is correct, which some the other thing Iā€™d verify).
