Logging into website with check
I’m trying to login from the login page of my site which opens up the next web page. I’m fairly new to k6 so I don’t know if I need and html look up function to find the places to put the login information. I want it to log in and check if it did and then get the next webpage after the login. So far I have this, thanks in advance. I know my script doesn’t even run but it gives you an understanding of what I’m trying to do. More or less a user scenario that I wouldn’t like to use the recording tool for.
import { sleep, group } from "k6";
import http from "k6/http";
export let options = {
    maxRedirects: 0,
    stages: [
    { duration: "30s", target: 5}, //simulate ramp-up of traffic from 1 to 5 users over 30 seconds
    { duration: "30s", target:5}, // stay at 5 users for 90 seconds
    { duration: "30s", target: 0},  //ramp down to 0 users over 5 seconds
export default function () {
    group('visit page and login', function () {
    // load homepage
    var url = 'https://socialscape.dev.sociallydetermined.com/login';
    var payload = JSON.stringify({
      email: 'aaa',
      password: 'bbb',
    var params = {
      headers: {
        'Content-Type': 'application/json',
    http.post(url, payload, params);
  check(res, {
    'is status 200': (r) => r.status === 200,
I answered you somewhat in the other thread (and, please, stop posting the same thing across multiple threads…). Besides the links I posted there, the following ones might also be of use to you:
Also, the problem with the current script seems to be that you’re not saving the result of http.post() anywhere, while you’re check()-ing a variable named res. So, this should be something like let res = http.post(url, payload, params);
