Hello
I am getting the following error when connecting to a loki container
dial tcp 127.0.0.1:8888: connect: connection refused
running podman on a windows OS
Any idea what the issue might be. Here is my compose file
version: "3"
networks:
loki:
services:
grafana:
image: grafana/grafana:latest
#user: "1000"
volumes:
- ../.podman_volumes/grafana:/var/lib/grafana
- ./config/grafana-datasources.yml:/etc/grafana/provisioning/datasources/datasources.yaml
ports:
- "9300:3000"
restart: unless-stopped
networks:
- loki
loki:
image: grafana/loki:2.8.2
volumes:
- ./config/loki:/etc/loki
ports:
- "3100:3100"
command: -config.file=/etc/loki/loki-config.yaml
networks:
- loki
promtail:
image: grafana/promtail:2.8.2
volumes:
- /var/log:/var/log
- ./config/promtail:/etc/promtail
- ./log/sql.log:/var/log/sql.log
#- /var/run/docker.sock:/var/run/docker.sock
# ports:
# - "1514:1514" # this is only needed if you are going to send syslogs
command: -config.file=/etc/promtail/promtail-config.yaml
networks:
- loki
