9.0.1 -
I want to create a bar chart that shows me the number of errors in a log per hour, such that I receive 24 bars (if range is set to a day). -
My current experiments with logql got me to:
count_over_time({job="syslog", host="$nodename"} |~ `(?i)error` [$__range])
What happened?
The output is continuous and there is a bar for every second (?)
Did you follow any online instructions? If so, what is the URL?
New in Grafana 8.4: How to use full-range log volume histograms with Grafana Loki | Grafana Labs
I tried to follow this except the sum_by level as I do not have a “level” label. Instead I’m using the filter function to achieve something similar.
