Loki Instance on EC2 VM - Send data to S3 and Indecies to Dyanamo DB
I installed Loki in EC2 VM which is running on port 3100 and promtail is sending my docker logs to Loki DB.
I need to change the pattern since my logs ingestion rate is bit high I wanted to send logs to S3 and Dynamo DB. Can someone help on this
Used Links:
@jangaraj : It would be greate if you stepin on this.
