I have deployed loki with loki-distributed 0.69.11
version.
I am not getting any error logs on loki-ingester container but still ingester container terminating and shutting down.
All other componant pods are running and up.
Here is loki-distributed.yaml file
loki:
structuredConfig:
server:
http_server_read_timeout: 600s
grpc_server_max_send_msg_size: 666561028
grpc_server_max_recv_msg_size: 666561028
# http_server_write_timeout: 600s
limits_config:
max_streams_per_user: 10000000
max_global_streams_per_user: 10000000
max_entries_limit_per_query: 4567587326
schema_config:
configs:
store: boltdb-shipper
object_store: azure
schema: v11
index:
prefix: loki_index_
period: 24h
storage_config:
boltdb_shipper:
shared_store: azure
active_index_directory: /var/loki/index
cache_location: /var/loki/cache
cache_ttl: 168h
azure:
container_name: xxx
account_name: xxx
account_key: ${STORAGE_ACCOUNT_KEY}
chunk_delimiter: ":"
ingester:
extraArgs:
- -config.expand-env=true
extraEnvFrom:
- secretRef:
persistence:
enabled: true
storageClassName: standardssd-lrs
resources:
requests:
cpu: 1000m
memory: 1024Mi
loki-ingester logs.
level=warn ts=2023-06-23T07:20:10.674992747Z caller=loki.go:286 msg="per-tenant timeout not configured, using default engine timeout (\"5m0s\"). This behavior will change in the next major to always use the default per-tenant timeout (\"5m\")."
level=info ts=2023-06-23T07:20:10.676055145Z caller=main.go:108 msg="Starting Loki" version="(version=2.8.0, branch=HEAD, revision=90888a0cc)"
level=info ts=2023-06-23T07:20:10.676772511Z caller=server.go:323 http=[::]:3100 grpc=[::]:9095 msg="server listening on addresses"
level=warn ts=2023-06-23T07:20:10.683785555Z caller=experimental.go:20 msg="experimental feature in use" feature="Azure Blob Storage"
level=info ts=2023-06-23T07:20:10.683781355Z caller=memberlist_client.go:437 msg="Using memberlist cluster label and node name" cluster_label= node=loki-distributed-ingester-0-17e72081
level=warn ts=2023-06-23T07:20:10.684012176Z caller=experimental.go:20 msg="experimental feature in use" feature="In-memory (FIFO) cache - embedded-cache"
level=warn ts=2023-06-23T07:20:10.684107285Z caller=cache.go:114 msg="fifocache config is deprecated. use embedded-cache instead"
level=warn ts=2023-06-23T07:20:10.684117786Z caller=experimental.go:20 msg="experimental feature in use" feature="In-memory (FIFO) cache - chunksembedded-cache"
level=warn ts=2023-06-23T07:20:10.684220895Z caller=experimental.go:20 msg="experimental feature in use" feature="Azure Blob Storage"
level=warn ts=2023-06-23T07:20:10.684266999Z caller=experimental.go:20 msg="experimental feature in use" feature="Azure Blob Storage"
level=info ts=2023-06-23T07:20:10.684317704Z caller=shipper.go:131 msg="starting index shipper in WO mode"
level=info ts=2023-06-23T07:20:10.684446616Z caller=table_manager.go:225 msg="loading table loki_index_19527"
level=info ts=2023-06-23T07:20:10.685135879Z caller=memberlist_client.go:543 msg="memberlist fast-join starting" nodes_found=1 to_join=4
level=info ts=2023-06-23T07:20:10.685477611Z caller=table.go:318 msg="handing over indexes to shipper loki_index_19527"
level=info ts=2023-06-23T07:20:10.685533916Z caller=table.go:334 msg="finished handing over table loki_index_19527"
level=info ts=2023-06-23T07:20:10.685564319Z caller=table_manager.go:225 msg="loading table loki_index_19528"
level=info ts=2023-06-23T07:20:10.686062364Z caller=table_manager.go:134 msg="uploading tables"
level=info ts=2023-06-23T07:20:10.686080066Z caller=index_set.go:86 msg="uploading table loki_index_19527"
level=info ts=2023-06-23T07:20:10.686195377Z caller=table.go:318 msg="handing over indexes to shipper loki_index_19528"
level=info ts=2023-06-23T07:20:10.699422192Z caller=memberlist_client.go:563 msg="memberlist fast-join finished" joined_nodes=2 elapsed_time=14.288113ms
Please let me know if i can try any solution here.
