I have been trying to get log information from grafana.log into loki use the logging driver but it does not seem to like something in my docker compose file.
Does anyone know how i can get the content of grafana.log sent to loki so I can see them in the explore tab in grafana?
version: "3"
networks:
loki:
influxdb:
services:
influxdb:
image: influxdb:1.7
restart: always
ports:
- '8086:8086'
volumes:
- influxdb-storage:/var/lib/influxdb
environment:
INFLUXDB_DB: actualdb
networks:
- influxdb
read:
image: grafana/loki:2.4.2
command: "-config.file=/etc/loki/config.yaml -target=read"
ports:
- 3100
- 7946
- 9095
volumes:
- ./loki-config.yaml:/etc/loki/config.yaml
networks: &loki-dns
loki:
aliases:
- loki
write:
command: "-config.file=/etc/loki/config.yaml -target=write"
ports:
- 3100
- 7946
- 9095
volumes:
networks:
<<: *loki-dns
grafana:
image: grafana/grafana:latest
environment:
- GF_PATHS_PROVISIONING=/etc/grafana/provisioning
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
depends_on:
- gateway
- influxdb
volumes:
- grafana-storage:/var/lib/grafana
entrypoint:
- sh
- -euc
mkdir -p /etc/grafana/provisioning/datasources
cat <<EOF > /etc/grafana/provisioning/datasources/ds.yaml
apiVersion: 1
datasources:
- name: Loki
type: loki
access: proxy
url: http://gateway:3100
jsonData:
httpHeaderName1: "X-Scope-OrgID"
secureJsonData:
httpHeaderValue1: "tenant1"
- name: InfluxDB_v1
type: influxdb
access: proxy
url: http://influxdb:8086
database: actualdb
user: admin
password: admin
editable: true
EOF
/run.sh
ports:
- "8080:3000"
networks:
- loki
- influxdb
logging:
driver: loki
options:
loki-url: "http://host.docker.internal:3100/loki/api/v1/push"
loki-pipeline-stages: |
- regex:
expression: '(level|lvl|severity)=(?P<level>\w+)'
- labels:
level:
extra_hosts:
- "host.docker.internal:host-gateway"
gateway:
image: nginx:latest
depends_on:
- read
- write
entrypoint:
- sh
- -euc
cat <<EOF > /etc/nginx/nginx.conf
user nginx;
worker_processes 16; ## Default: 1
events {
worker_connections 1000;
http {
resolver 127.0.0.11;
server {
listen 3100;
location = / {
return 200 'OK';
auth_basic off;
location = /api/prom/push {
proxy_pass http://write:3100\$$request_uri;
location = /api/prom/tail {
proxy_pass http://read:3100\$$request_uri;
proxy_set_header Upgrade \$$http_upgrade;
proxy_set_header Connection "upgrade";
location ~ /api/prom/.* {
location = /loki/api/v1/push {
location = /loki/api/v1/tail {
location ~ /loki/api/.* {
EOF
/docker-entrypoint.sh nginx -g "daemon off;"
ports:
- "3100:3100"
networks:
- loki
volumes:
grafana-storage:
external: true
influxdb-storage:
external: true
References:
