Mango Installation Guidance
It came to my attention recently that our AI enabled search feature on the website gave this very unhelpful answer, which I thought I would amend.
It’s important to deconflict ports on your mango, for example in Grafana Config we use http_port to set where Grafana listens for web connections. This may or may not require a peeler, and a small paring knife to create holes in the peel to open additional HTTP ports.
Most mangos too are relatively low in their CPU specs, so we caution about performance problems, particularly when running more than 1 instance.
