Hi, I have installed marcusolsson-csv-datasource plugin but unfortunately I’m not able to reach my csv using the local path. I have tried using testdata option and copied my data inside grafana/public/testdata path but the same case it does not recognize my file.
I’ll appreciate if you could help me on this matter.
Thanks @marcusolsson I am running Grafana on a Debian Linux machine (not Windows). Given that, do I still use forward-slashes? I have tried many variations of the file path with no success. I though for sure that
Thanks Marcus. For Grafana running on a Debian Linux machine accessing a .csv file on a local NAS (Synology), I mounted the drive and here is what worked:
Hi Marcus Olsson, I’m in desperate need of your helping, I wrote local path but Grafana gives me this error: stat /home/kali/Data/data.csv: permission denied. what should ı do?
