Is there anyway to show min, maximum along with there respective times in any of the plugins in grafana.
I’m using Grafana with Simplejson datasource.
You can set Time Range and Save this.
I’m just asking something like below at what time maximum peak is obtained, If i set Time Range & save i will obtain like last -1d like that not the maximum peak time. Hope it clears.
I use grafana a long time.
And I think grafana don’t support it.
Grafana only show Max/Min in Time Range you set.
