Missing datapoints with push/influx/write endpoint
Hi all,
i try to push metrics through the influx write endpoint.
I noticed, that if i ingest for the same time series multiple datapoints every 10 seconds, i only see them once per minute (testing the influx write endpoint).
Questions
  • How does this work now internally between Prometheus and the write endpoint?
  • You scrape it once per minute and take the latest value for the specific series?
  • So in case i have a metric for measuring/capturing something in seconds, that won’t work with the write endpoint?
  • Can i add meta information to the endpoint? How can attach logs/traces to metrics?
I guess you didn’t configure min step for your query:
