Missing median metric aggregation for elasticsearch data source
I am transferring Kibana dashboards to Grafana. I am achieving this by using Elasticsearch as a data source, copying the query and selecting the same metrics, interval, etc. as in Kibana.
This looks like this:
Unfortunately, one dashboard uses the median aggregation, which I am not able to find in Grafana.
Do you know a solution to this problem or is there maybe a workaround by using expressions? I am using the “Time series” visualization.
Grafana Version 9.0.5
Probably it is too late but actually, to get the median in the dropdown menu where you can get “Average”, “min” or “max” you have to select “Percentiles” and then keep only the value “50” in the “Percentiles” field. Indeed the 50th percentile corresponds to the median.
