Monitor mongo dB api using Prometheus and grafana
I need to monitor api to mongo database to check that database run and healthy.
can help how do this and steps?
thank to all
What have you tried so far?
Those were just the first few results I found from Google. Let us know what
you’ve tried and what problems you ran into.
Antony.
how monitor database if up and running and not responded in standalone server not container
Yes, I know what you are trying to achieve. I’m asking what you have tried so
far out of the several ways to do this which I found from a Google search, so
that we might be able to help you with any problems you have encountered.
If you’re simply asking “can someone tell me how to do this?” then try the
three links I posted in my previous reply, and see whether any of those are
suitable solutions to your requirement.
Regards,
Antony.
ok , thanks for you help
