Now that 5.0 is released and we can do teams and folders, I would like to consolidate and move away from Orgs. Is there a way to move dashboards between orgs? Or a way to do a mass export of all dashboards in an org?
There’s no support for this in Grafana UI. But you can use the http api to accomplish what you want.
You should also be able to use wizzy.
Marcus
Perfect thanks. I can’t believe I didn’t think about the API. My first response to everything is can I do it through an API…
