MS-SQL: Visualize multiple series in Time Series Graph panel with multi-value variable in query statement?
    v.9.3.2
    I want to visualize multiple series in a Time Series graph panel with multi-value variable in my query statment.
    For example on play.grafana.com:
    You can see for every web-server a series.
    I tried different solutions, but it not work with multi-value variable (The multi-value variable is to set the different series)
    My first solution:
    Write multiple query statements for every webserver (no multi-value variable)
    Then it works, but without multi-value variable. It’s static…
When i create the one query with use of multi-value variable, i get only one series because i retrieve only one dataset.
    I want a vizualitation like this one Edit panel - Grafana
    Check picture.
    No.
    I didn’t find any solution…
Welcome,
Do you not have the server name that maps to webserver field? in your example you have 645.
If you use the following transformation
Then you do not need multiple queries. And obviously multi queries would not scale if you have more servers
Thank you so much! It work’s! Didn’t know that transformation opportunity ! :slight_smile:
