Windows - v7.5.3 -
My graph works, per se. I am just looking to have the x-axis display the values it pulls from the query in created (time) column using the following queries:
select cast(created as date) time, (select count(*) from trending where status='Puppet Missing/Broken' and created=time) Puppet FROM trending ORDER BY time
select cast(created as date) time, (select count(*) from trending where status='Nessus Missing/Broken' and created=time) Nessus FROM trending ORDER BY time
select cast(created as date) time, (select count(*) from trending where status='Scanned' and created=time) Scanned FROM trending ORDER BY time
select cast(created as date) time, (select count(*) from trending where status='Exception' and created=time) Exception FROM trending ORDER BY time
- What did you expect to happen?
I was hoping to have the x-axis display each value in the created (time) column. And, have it reflect all of the data being returned, out to 11/29 as of this posting. It only goes out to 11/20 at the moment.
Thanks!
