Need help adding integration home assistant to grafana agent
I am currently struggling with adding the homeassistant integration to grafana-agent and would appreciate if someone could help me!
Here is my setup:
home assistant and grafana agent are both running in a k3s (v1.23.3+k3s1). Prometheus is successfully scraping the home assistant metrics and curling them with curl http://<EXTERNAL IP>:8123/api/prometheus -H 'Authorization: Bearer <BEARER TOKEN' is also successful, so I guess it is not a token issue.
I used the “grafana-easystart-app/kubernetes” way of installing a
My grafana-agent has the following configmap:
metadata:
  namespace: monitoring
apiVersion: v1
data:
  agent.yaml: |
    server:
      http_listen_port: 12345
    integrations:
      node_exporter:
        enabled: true
      prometheus_remote_write:
        scrape_configs:
        - job_name: integrations/hass
          metrics_path: /api/prometheus
          bearer_token: "<TOKEN>"
          scheme: https
          static_configs:
            - targets: ['<EXTERNAL IP>:8123']
I have already tried the following:
changing the External IP to
  1. namespace.servicename
  2. service-ip
Changing the bearer_token to:
  1. “”
  2. ‘’
So far nothing has worked and the status of the job integrations/hass stays at 0.
Implementing it via prometheus “remote_write” seems to work. However, I would like the grafana agent to work aswell.
Any tips or anything I am missing here?
Thanks in advance!
The Grafana Agent needs to use remote_write to send data back to Grafana Cloud’s Prometheus backend.
thanks for the answer. I believe I do not really get your answer. In general, metrics are received at the grafana clouds prometheus backend. Simply, the home assistant integration does not seem to work…
