Need help to replace variables in from clause
I have created two variable
suppose variable dc=DRWP_DEV_C121 & host=wp121
i want to repalce those variables in from clause ie in measurement name
i have tried many things in data query but not getting work. between two variables there is spacial character “_”
when i tried below the host is getting repaced but dc was not … getting result ==> wp121.jvm.daemon_thread_count
SELECT mean(“value”) FROM “/$dc”_"$host.jvm.daemon_thread_count" WHERE $timeFilter GROUP BY time($__interval) fill(null)
then i tried below also … this is also not getting work
SELECT mean(“value”) FROM “{$dc}_{$host}.jvm.daemon_thread_count” WHERE $timeFilter GROUP BY time($__interval) fill(null)
my final expectation is data query should return — > DRWP_DEV_C121_wp121.jvm.daemon_thread_count
Can anyone help me here, how should i write data query.
I was able to reproduce your problem. But I found a solution using a mix with the other variable reference format, i.e.
FROM "/[[dc]]_$host.jvm.daemon_thread_count"
WHERE $timeFilter
Marcus
yes, it’s works, Thanks Marcus.
