Hi!
There is a problem in the environment, I’m using grafana to view the zabbix data.
I used variables to replicate panels, when the “all” option is set in the variable, some interfaces are “no data”, but when I select these interfaces in the variable, their values appear, can someone help me?
Grafana Version: 8.4.1
Zabbix Plugin Version: 4.2.5
below is the print of when the variable is set to “all”:
below is the print of when the variable is set in the specific interfaces:
help, please
is the variable derived from existing data or hand carved? Can you show us your drop down variable source?
Thanks for answering.
My variable follows a regex that takes all the network interfaces of a host
right after I configure items, some graphics work on the same line and others that follow the same line, don’t work, unless I selected them variable
And what does the query look like in the viz that accepts the value from the $variable
The query is as follows…
In zabbix, there is a group called “FIREWALL” and within this group there are several hosts, these hosts exist “network interfaces”, in the variable I am getting the value of a host that is within a group and is pulling all interfaces this host’s network
