No exported functions in script
So i followed the instructions here: app.k6.io - Performance testing for developers, like unit-testing, for performance
These instructions do not work. I raised this with support, and they said “they would let dev team know”. As a paying customer, I just want to underline how terrible this is, that support cannot answer basic setup questions, and documentation is incorrect. But I digress.
My project id is: 3567859
My project name is “testname”
When i create the script.js file entire contents are:
export let options = {
  ext: {
    loadimpact: {
      projectID: 3567859,
When i run the file with k6 cloud script.js i get:
/ __________ \ |__| _\ ____/ .io
ERRO[0000] no exported functions in script
What exactly is the problem? The “testname” script runs perfectly well from the gui, am i missing something?
Your test still needs some code to run, right? Options are meaningless if you don’t specify what should be executed, so you still need to export a default function, see this for details: Running k6
