Not able to achieve 2000RPS using constant arrival rate executors. Any suggestion?
my_api_test_constant_arr_rate_vu: {
executor: 'constant-arrival-rate',
rate: 2000,
duration: '1s',
timeUnit: '1s',
preAllocatedVUs: 2,
maxVUs: 500,
Output:
scenarios: (100.00%) 1 scenario, 500 max VUs, 31s max duration (incl. graceful stop):
* my_api_test_constant_arr_rate_vu: 2000.00 iterations/s for 1s (maxVUs: 2-500, exec: getQuotes, gracefulStop: 30s)
running (01.4s), 000/348 VUs, 945 complete and 0 interrupted iterations
my_api_test_constant_arr_ra... ✓ [======================================] 000/348 VUs 1s 2000.00 iters/s
Hi @subhasis
Assuming the System Under Test can keep up with the load, you would probably need to set this up differently.
preAllocatedVUs: 2
. The test will start with 2VUs, which might not be enough to reach the 2000 rps in 1s. And k6 will allocate more VUs up to maxVUs: 500
, which will probably take more than 1 second.
duration: '1s'
is probably too short anyway, even if you set preAllocatedVUs: 2000
which would start the 2000
iterations at the same time (if there are enough resources in the load generator).
I would recommend you have a read at:
You can try:
rate: 2000,
duration: '1s',
timeUnit: '1s',
preAllocatedVUs: 2000,
Though the duration might be too short for the iterations to finish. And for that I would try increasing the duration
. Based of course on what type of test you need to run, what you want to achieve.
I hope this helps.
Cheers!
