i added the custom metrics in telegraf configuration as below
Read the metrics from uname command
[[inputs.exec]]
commands = ["uname -r"]
timeout = "5s"
data_format = "value"
data_type = "string"
Now i’m trying the view the uname output in grafana dashboard
i tried the below query to view the output but i’m not able to view the output of uname command in the grafana dashboard and how i have to write the query to fetch this uname /any other custom command output in grafana dashboard . i’m using influxdb as datasource
. please help on this
SELECT * FROM “exec” WHERE “command” = ‘uname -a’
THANK YOU!!
What do you get when you run uname -r in the command line of the target host?
Maybe you need to specify location of that function: /usr/bin/uname
Etc wherever it is located?
Uname -r command is used to get the kernel details.
For example if i want to get the output of lmstat command (which is used to get licence properties). I want this command output to be displayed in grafana dashboard.
What steps need to be done .
Not only this command if any other command i need to get the output in grafana dashboard what steps need to be done.
Please help me
No, I am asking you if you ran that command in the host you are scrapping data from what do you get, does it work?
Also did you try what was recommended
/usr/bin/uname
