const browser = chromium.launch({
headless: false,
timeout: ‘2m’
i still get
ERRO[0034] Uncaught (in promise) waiting for function, polling: timed out after 30000ms executor=per-vu-iterations scenario=browser
can someone help me to override default timeout
Hi @arvind_patel ,
Could you please send us the whole script after removing possibly sensitive parts? Thanks.
@inanc
import { chromium } from 'k6/experimental/browser';
import { check, sleep, expect } from 'k6';
import exec from 'k6/execution';
export const options = {
scenarios: {
browser: {
executor: 'per-vu-iterations',
exec: 'browser',
vus: 3,
iterations: '1'
//duration: '5s',
export async function browser() {
console.log('---------------------- user no ------------------ ' + exec.vu.idInTest);
headless: false,
timeout: '2m',
userDataDir: "'./chromeProfiles'" + exec.vu.idInTest,
const context = browser.newContext(); //one browser instance
const page = context.newPage(); // one tab
page.setViewportSize({
width: 800,
height: 720,
}); try {
page.setDefaultTimeout(90000);
await page.goto('https://www.google.com/', { waitUntil: 'networkidle' });
page.waitForSelector("div[class$='overlay-box']");
page.waitForNavigation();
await page.waitForFunction('document.querySelector("div[class$=****]") === null'); // wait till the overlay go away
page.waitForSelector("#****");
await page.mouse.move(500, 300);
await page.mouse.click(500, 300);
console.log('--------------vu number : ' + exec.vu.idInTest);
console.log("my page is " + context.pages().length); //no of tabs
sleep(10);
} finally {
page.close();
browser.close();
@inanc anything i am missing ?
ankur
June 19, 2023, 3:29pm
5
Hi @arvind_patel ,
It looks like you’ve hit upon an issue that we were unaware of. I’ve created an issue (#940 ) that you can track. We’re not sure when we will be able to get to this though unfortunately.
In the meantime you can work with browserContext.setDefaultTimeout
(there’s an issue (#456 ) with this API too, which is that it interprets the input in seconds not milliseconds). So you should be able to work with the following change where I’ve added context.setDefaultTimeout(90);
after the context has been created:
headless: false,
timeout: '2m',
context.setDefaultTimeout(90); // 90 seconds
Cheers,
Ankur
@ankur thanks for the work around. it worked
