- What Grafana version and what operating system are you using?
v8.3.3 (30bb7a93ca)
Create contact points by API. -
That’s my question
Hello!
Ansible Collection for Grafana maintainer here 0/
We have a module that used to allow to create notification channels on previous versions of Grafana.
Since 8.3 and the change around alerting management, I’d like to know if there is an API endpoint that we can safely use to create contact points to keep the capability we used to have.
I did not see any enpoint in the HTTP API doc and saw through browser network tab that it is totally new.
Thanks !
