I also edit the .ini file to [unified_alerting] enabled = true
any update on this? still no resolution yet.
Does notification policies is same? Or COntact points same?
If you are running the latest version of Grafana OSS, then I believe you will not need to modify the .ini file, as the new Unified Alerting is standard (no longer optional via configuration of the .ini file).
