Number of records per hour JSON
    v8.3.5
    To build time series from JSON formatted data. I would like to use one base table panel with almost “real-time” orders data. I use Infinity plugin for getting the metrics from API. Data is provided by API every 10 minutes which returns JSON . Example JSON:
        "order_id": "US-123",
        "store": "USA-1",
        "total_amount": "12.25",
        "items_ordered": "1",
        "timestamp": "1648119600"
        "order_id": "US-235",
        "store": "USA-1",
        "total_amount": "24.25",
        "items_ordered": "2",
        "order_id": "DE-212",
        "store": "Germany-1",
        "total_amount": "43.25",
        "timestamp": "1648634400"
        "order_id": "AT-452",
        "store": "Austria-1",
        "total_amount": "125.12",
        "items_ordered": "5",
        "timestamp": "1648641600"
        "order_id": "AT-245",
        "total_amount": "62.23",
        "items_ordered": "3",
        "order_id": "CA-321",
        "store": "Canada-1",
        "total_amount": "90.55",
        "timestamp": "1648846800"
I would like to use this panel as a parent for all other time series panels like:
hourly order count by stores, hourly order total amount by stores and etc.
    I successfully created a filled table from API. Now I try to inherit the results in other panel “orders hourly”. In “orders hourly” panel I used “Organize fields”
    transformation and hide unnecessary fields for this panel: order_id, total_amount, items_ordered. Also I used “Convert Field Type” transformation to format the timestamp to hourly based format like (YYYY-MM-DD HH). So only “timestamp” and “store” left in the “orders hourly” panel.
  • What happened?
    I can’t seem to find how to group by “timestamp” AND “store” to have a total orders count by store in each hour. I tried to use “Group By” transformation for timestamp field, and it grouped the timestamp, but I lose the store count information.
    To have a matrix from timestamp and store. Count orders by store for every hour.
The question can confuse, so please let me know if you need more information.
Welcome
Which kind of dashboard visualization are you using?
I would say “table”? I am trying to use time series, but I don’t have number value for it, and I don’t know how to build a matrix from given JSON (timestamp and store values).
sorry forgot to ask, which plugin are you using to read the json?
Infinity: GitHub - yesoreyeram/grafana-infinity-datasource: CSV, JSON, GraphQL, XML and HTML datasource for grafana.
here is something that can get you started and you can run with it. infinity itself can do a lot of great things for you out of the box
parse-json
| extend "orderqty"=tonumber("items_ordered"), "orderdate"=unixtime_seconds_todatetime("timestamp")
| summarize "sum by store"=sum("orderqty") by "store", "orderdate"
the following values in your json are problematic as they are string
which required UQL conversions. Might want to look into why that is.
Thank you for the tip. I see you built a great example of getting Total Ordered Items by store. But how can I collect Total Orders by store?
The sample query I gave you should give you a hint so you can fly :bird: on your own. Try things out on your own and see where you get.
read the documentation
Thank you! By the way, do you know any kind of tool/plugin which can handle post-data processing? For instance, in order to save performance, I would like to have only 1 api call to my server, and response of that call have everything what is needed. I could have several child panels using the result of the parent panel. UQL is only available for parent panel, and I can do nothing with it in child panels, transform possibilities are limited. Maybe there is a similar query tool? I can’t seem to understand how it works, maybe you could give a hint/link to docu here?
Did you read thia fully?
Yes, I read it. But still I cannot find out how to use it in child panels.
