I refer to the topic I recently created with the same title, blocked by Akismet and yet to be reviewed / released by moderators. It contains a GIF showing the behaviour, which is best viewed with one’s own eyes:
When viewing a certain dashboard created in Grafana Cloud, on my Samsung Galaxy S9, the dashboard constantly resizes / reforms itself and does not ‘settle’ - meaning you can’t select or view anything. Other dashboards are fine. I do not know how to proceed. I attached the GIF and the dashboard configuration to the previous post, but I think this is what has got it blocked.
Cloud (free, soon to be pro) -
View dashboards on a Samsung Galaxy S9 -
Navigate to [mycompany].grafana.net and then to the dashboard, using Chrome for Android -
What happened?
As above -
Page loads normally and doesn’t constantly resize -
As per blocked post -
No -
Did you follow any online instructions? If so, what is the URL?
Couldn’t find any
