Open dashboard panel no data ,after i click panel edit ,have data
centos8.5
zabbix6.0
grafana8
the problem is when i open a dashboard ,all panel no data,but when i select a panel and click edit ,the data OK
so i must do click panel edit ,why?
@ba13911359590 I’m curious what might be different before/after clicking edit.
Can you share the output of the request portion of inspect query? I suggest comparing both queries to see if anything is different.
Screen Shot 2022-04-15 at 12.18.28 PM
The zabbix plugin is community supported. If the queries look the same you might also:
