OpenTSDB query tags to rows and columns
    v8.1.8
    I’ve an OpenTSDB query that has 2 tags of my interest podName and stepNumber. What i’m trying to do is extract these fields and use podName as row and stepNumber as column and the metrics values in the table cells.
Query:
ALIASBYTAG(-1h:synthetics..AGG.all:kaiju_CUJ__-CRM-All-__Edit__case_availability{location=,podName=,testCaseId=32062,ownerId=1957,level=testStep,stepNumber=}:avg, #podName#, #stepNumber#)
    I’ve tried using series to rows transform but that gives me a metric field with “podName,stepNumber” as values and the Value field has the metrics value.
  • What happened?
    I’m unable to transform these fields to rows and columns.
    It displays the table like this
time               podName,step      Values
12:12:12.             xy01,1                -1
12:12:15.             gh03,3                1
                   step1   step2
podName1       1.         1
podName2       1        -1
podName3       1          0
    No
