Organize Calculated Fields
Grafana v9.2.6
I have Grafana connected to Opensearch data source. I am getting data from an index.
I have a column with a unix epoch type:
I want to convert this into datetime.
The thing is that I don’t have a way to execute a query, I’d be able to convert the type or multiply by 1000.
What I found is create an add field from calculation transform:
And add an override type:
The result is the following one:
  • Is it possible to hide the column Start time where I’m doing the operation?
  • I can’t organize the calculated fields, there’s no way to move them to another position even editing manually the JSON model. Can I use another alternative?
I took a look to different posts but I couldn’t find something that can be done without editing a SQL query.
Thank you very much.
