following errors are generated when using experimental prometheus or even xk6 prometheus remote write option
Why out of sample orders are generated when running k6 locally ?
Hey @patenvy,
the remote write output has some checks for preventing it so this case could be a bug.
Can you report what version of k6 and Prometheus you are using and the command that you’re using for running k6?
I see you’re testing test-api.k6.io
so probably your script does not include any private metadata. Can you share it as well?
Thanks.
