Override regex not working
    8.4.4 on docker
    Change the series style to Bar in the timeseries graph for several queries by using a regex-overwrite.
    By using regex
  • What happened?
    Nothing, all graphs are still shown as Lines.
    The temperature graphs ‘TempNick’ and ‘TempWZ’ to be displayed as bar-graphs.
    These are the queries in place:
SELECT
  ts/1000 AS "time",
  val AS 'WP'
FROM ts_number
WHERE
  $__unixEpochFilter(ts/1000) AND
  id = 48
ORDER BY ts ASC
SELECT
  ts/1000 AS "time",
  val AS 'TempNick'
FROM ts_number
WHERE
  id = 71
ORDER BY ts ASC
SELECT
  ts/1000 AS "time",
  val AS 'TempWZ'
FROM ts_number
WHERE
  id = 73
ORDER BY ts ASC
    No
    Configure field overrides | Grafana documentation
  • Observations
    When using Override option ‘Fields with name’, the only possible selections are
Thus I’d assume the regex should be able to filter on excatly those, but:
  • When I change the regex to .* all 3 queries are displayed as bar-graphs.
  • When I change the regex to .*W.* all 3 queries are displayed as bar-graphs.
  • When I change the regex to .*WP.* nothing happens.
  • When I change the regex to .*Temp.* nothing happens.
  • When I change the regex to /.*Temp.*/ nothing happens.
  • When I change the regex to /Temp.*/ nothing happens.
  • When I change the regex to Temp.* nothing happens.
When I try the same in play.grafana.org by adding XX to some querie aliases it works with pattern XX.* !
Any ideas what’s going wrong?
Thxs
so this is working on play.grafana but not on the 8.4.4 docker image?
yes, that’s correct. When it was not working in docker 8.4.4 I tried in play.grafana and had no issues there.
