Panel/Data links in every newly created panel
Hey,
I need to create panel and data links, that opens a new tab to a different website, automatically in every panel that is created (or dashboard that is imported) by me or by any of my team members. I wanted to know what is the best way to do this? I looked at Linking but that seems to only work manually, going over each panel and adding the links through the grafana dashboard. I also looked at
Data Source plugin but I am not sure if its the correct use case and if what I need is supported.
Any help will be much appreciated, and If there is an example for such use case that would be awesome.
Thanks!
