Hello to all,
After a late update of my Grafana 9.0.7 installation to the latest version 9.5.1, I have a problem displaying only on devices with a touch screen.
The menu of modification, sharing, etc of the panels is displayed permanently.
I don’t have this problem on my desktop.
Is there a setting so that Grafana does not take into account the touch screen?
On a tablet :
On a desktop no problem :
Thanks for your help !
Sorry for my bad english
Hi @razor83,
Welcome to the
community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community
What is the touch device e.g. Android, Apple etc?
Also, if I understand you correctly, you do not want the 3 vertical dots to be displayed on the touch device?
Hi @usman.ahmad,
All Android, my Oneplus 8T and a Lenovo small tablet.
I’ve tried Chrome/Firefoxe with and without desktop mode.
Yes you understood
The 3 dot do not show on my desktop, only wen my mouse goes over a panel, but on touch screen they stay visible.
Thx!
Same behaviour here. The dashboard I built looks horrible now…
I’d be glad if one could hide the panel menu entirely
edit: this started with grafana 9.5.0. Downgraded to 9.4.9 and the problem is gone.
Hi @razor83 and @buesche,
So there is a workaround to hide those 3 dots so that it don’t get selected when viewing it on the touch devices i.e.
Goto that particular Dashboard → Settings → Permissions and select "view only for viewer and editor.
Then should do the trick.
More better approach is to use the Public Dashboards (link to documentation)
I hope this helps.
