Parsing k8s nginx ingress logs and extracting labels not working
I have been trying to extract certain labels out of nginx ingress logs from my k8s cluster but unfortunately it doesn’t seem to work.
I have added the following configuration to promtail config map and also verified that the configuration is loaded in the promtail daemon set but I don’t see any of the custom labels in grafana .
I have enabled debug logging too but can’t find any errors …, Any idea what might be wrong ?
apiVersion: v1
data:
  promtail.yaml: |
    client:
      backoff_config:
        max_period: 5m
        max_retries: 10
        min_period: 500ms
      batchsize: 1048576
      batchwait: 1s
      external_labels: {}
      timeout: 10s
    positions:
      filename: /run/promtail/positions.yaml
    server:
      http_listen_port: 3101
    target_config:
      sync_period: 10s
    scrape_configs:
    - job_name: kubernetes-pods-name
      pipeline_stages:
        - docker: {}
        - match:
            selector: '{job="nginx/nginx-ingress"}'
            stages:
            - regex:
                expression: '^(?P<remote_addr>[\w\.]+) - (?P<remote_user>[^ ]*) \[(?P<time_local>.*)\] "(?P<method>[^ ]*) (?P<request>[^ ]*) (?P<protocol>[^ ]*)" (?P<status>[\d]+) (?P<body_bytes_sent>[\d]+) "(?P<http_referer>[^"]*)" "(?P<http_user_agent>[^"]*)"?'
            - labels:
                remote_addr:
                remote_user:
                time_local:
                method:
                request:
                protocol:
                status:
                body_bytes_sent:
                http_referer:
                http_user_agent:
      kubernetes_sd_configs:
      - role: pod
      relabel_configs:
      - source_labels:
        - __meta_kubernetes_pod_label_name
        target_label: __service__
      - source_labels:
        - __meta_kubernetes_pod_node_name
        target_label: __host__
      - action: drop
        regex: ''
        source_labels:
        - __service__
      - action: labelmap
        regex: __meta_kubernetes_pod_label_(.+)
      - action: replace
        replacement: $1
        separator: /
        source_labels:
        - __meta_kubernetes_namespace
        - __service__
        target_label: job
      - action: replace
        source_labels:
        target_label: namespace
      - action: replace
        source_labels:
        - __meta_kubernetes_pod_name
        target_label: pod
      - action: replace
        source_labels:
        - __meta_kubernetes_pod_container_name
        target_label: container
      - replacement: /var/log/pods/*$1/*.log
        separator: /
        source_labels:
        - __meta_kubernetes_pod_uid
        target_label: __path__
    - job_name: kubernetes-pods-app
      pipeline_stages:
        - docker: {}
      - role: pod
      relabel_configs:
      - action: drop
        regex: .+
        source_labels:
      - source_labels:
        - __meta_kubernetes_pod_label_app
      - source_labels:
      - action: drop
        regex: ''
        source_labels:
        - __service__
      - action: labelmap
      - action: replace
        replacement: $1
        separator: /
        source_labels:
        - __service__
        target_label: job
      - action: replace
        source_labels:
      - action: replace
        source_labels:
        target_label: pod
      - action: replace
        source_labels:
        separator: /
        source_labels:
    - job_name: kubernetes-pods-direct-controllers
      pipeline_stages:
        - docker: {}
      - role: pod
      relabel_configs:
      - action: drop
        regex: .+
        separator: ''
        source_labels:
      - action: drop
        regex: '[0-9a-z-.]+-[0-9a-f]{8,10}'
        source_labels:
        - __meta_kubernetes_pod_controller_name
      - source_labels:
      - source_labels:
      - action: drop
        regex: ''
        source_labels:
        - __service__
      - action: labelmap
      - action: replace
        replacement: $1
        separator: /
        source_labels:
        - __service__
        target_label: job
      - action: replace
        source_labels:
      - action: replace
        source_labels:
        target_label: pod
      - action: replace
        source_labels:
        separator: /
        source_labels:
    - job_name: kubernetes-pods-indirect-controller
      pipeline_stages:
        - docker: {}
      - role: pod
      relabel_configs:
      - action: drop
        regex: .+
        separator: ''
        source_labels:
      - action: keep
        source_labels:
      - action: replace
        regex: '([0-9a-z-.]+)-[0-9a-f]{8,10}'
        source_labels:
      - source_labels:
      - action: drop
        regex: ''
        source_labels:
        - __service__
      - action: labelmap
      - action: replace
        replacement: $1
        separator: /
        source_labels:
        - __service__
        target_label: job
      - action: replace
        source_labels:
      - action: replace
        source_labels:
        target_label: pod
      - action: replace
        source_labels:
        separator: /
        source_labels:
    - job_name: kubernetes-pods-static
      pipeline_stages:
        - docker: {}
      - role: pod
      relabel_configs:
      - action: drop
        regex: ''
        source_labels:
        - __meta_kubernetes_pod_annotation_kubernetes_io_config_mirror
      - action: replace
        source_labels:
        - __meta_kubernetes_pod_label_component
      - source_labels:
      - action: drop
        regex: ''
        source_labels:
        - __service__
      - action: labelmap
      - action: replace
        replacement: $1
        separator: /
        source_labels:
        - __service__
        target_label: job
      - action: replace
        source_labels:
      - action: replace
        source_labels:
        target_label: pod
      - action: replace
        source_labels:
        separator: /
        source_labels:
kind: ConfigMap
metadata:
  annotations:
    meta.helm.sh/release-name: loki
    meta.helm.sh/release-namespace: monitoring
  labels:
    app: promtail
    app.kubernetes.io/managed-by: Helm
    chart: promtail-2.2.0
    heritage: Helm
    release: loki
I was trying to solve the same issue and also hit this problem. In my situation, the root cause makes total sense when you think about it, but wasn’t entirely obvious up front.
In simple terms, your regex defined like that will never match. From my understanding of promtail, the output of one stage does not get fed into the next, meaning the docker stage does not get fed into the input of your match stage.The docker stage expects the log line to match a specific json format, and I assume this part works for you. But the regex for match is looking for a raw nginx access log format, not an nginx access log entry encapsulated into a docker entry.
If you look at the pipeline stages documentation, you’ll see docker is just a wrapper for a configuration; you will need to incorporate your match stage into this - likely just remove the docker and replace with the wrapper, and add your match there.
On my cluster, I’m using the cri stage (instead of docker) and it does something very similar, my expression ended up being the following:
            - match:
                selector: '{app="nginx-ingress-microk8s-controller"}'
                stages:
                  - regex:
                      expression: '^(?s)(?P<time>\S+?) (?P<stream>stdout|stderr) (?P<flags>\S+?) (?P<remote_addr>[\w\.]+) - \[.*\] - (?P<remote_user>[^ ]*) \[(?P<time_local>.*)\] "(?P<method>[^ ]*) (?P<request>[^ ]*) (?P<protocol>[^ ]*)" (?P<status>[\d]+) (?P<body_bytes_sent>[\d]+) "(?P<http_referer>[^"]*)" "(?P<http_user_agent>[^"]*)"? (?P<request_length>[\d]+) (?P<request_time>[\.\d]+) \[(?P<proxy_upstream_name>[^\].]*)\] \[(?P<alt_proxy_upstream_name>[^\].]*)\] (?P<upstream_addr>[^ ]*) (?P<upstream_length>[\d]+) (?P<upstream_time>[\.\d]+) (?P<upstream_status>[\d]+) (?P<request_id>[^"]*).*'
                  - labels:
                    ...etc...
As you can see, I had to incorporate the nginx regex into the regex for cri, so it would match the whole line. I don’t know if this is the “correct” way to do it, but I was unable to find an alternative or any indication in the docs there is another method. I also added several more captured groups to the regex.
Hope this helps!
You should avoid extracting data specially IP address to index it. Pipelines allows you to add to the index. If you want to work with this data use LogQL and parsers at query time easier to experiment LogQL | Grafana Labs
@cyriltovena Ah yes, great point. In my case, nginx is internal only so the cardinality on IPs is limited to just a handful of values. But I have removed extracting on a number of other fields, especially the request and referrers since they are generally dynamic in value.
