Periodically refreshing a token aside a script
Hi everyone,
I’ve the following issue : I’m currently scripting a user journey. The authentication needs to be refreshed every 5 seconds while I’m running my test.
In other load testing tools I would have use a while loop inside a fork but here, I don’t even see a correct solution.
has anyone already faced this problem ? How did you solved it ?
Thanks in advance !
Hi @camillegr,
welcome to the community forum :tada:
If you can use a dedicated token per VU then you can check the time elapsed from the last refresh and execute a new one after 5 seconds.
var refreshed = 0;
export default function() {
	var diff = new Date() - refreshed
	if (diff > 4999) {
		console.log(`refresh the token`)
		refreshed = new Date()
Even better if you create an HTTP wrapper where this logic is executed before each request so the code will be cleaner.
When the PR for #882 will be merged then a setTimeout could be a valid alternative. You can subscribe to it to know when it will be available.
Hi @codebien,
I think the http wrapper is a good solution. I’ll take a look at it.
thanks for your answer !
in my scenario, i want to generate a token and use it for 10 mins (validity ) Please help me to understand more about this logic, Where should we add this code, should we add this to generate token API or before using a token
my scenario looks like
import { group } from ‘k6’;
import {check , sleep} from ‘k6’;
import http from ‘k6/http’;
import { htmlReport } from “K6 Load Test: <%= title %>”;
import { textSummary } from ‘https://jslib.k6.io/k6-summary/0.0.1/index.js
import { SharedArray } from “k6/data”;
import papaparse from “https://jslib.k6.io/papaparse/5.1.1/index.js”;
import encoding from ‘k6/encoding’;
import { findBetween } from ‘https://jslib.k6.io/k6-utils/1.2.0/index.js’;
export const options = {
scenarios: {
setup: { // some arbitrary scenario name for genarate token
executor: ‘per-vu-iterations’,
vus: 1,
//duration: ‘1s’,
iterations: 2,
gracefulStop: ‘0s’, // do not wait for iterations to finish in the end
tags: { test_type: ‘setup’ }, // extra tags for the metrics generated by this scenario
exec: ‘setup’, // the function this scenario will execute
scenario1: { // some arbitrary scenario name
executor: ‘constant-vus’,
//executor: ‘per-vu-iterations’,
vus: 15,
duration: ‘60m’,
//iterations: 10,
tags: { test_type: ‘scenario1’ }, // extra tags for the metrics generated by this scenario
exec: ‘scenario1’, // the function this scenario will execute
scenario2: { // some arbitrary scenario name
vus: 15,
duration: ‘60m’,
//iterations: 10,
tags: { test_type: ‘scenario2’ }, // extra tags for the metrics generated by this scenario
exec: ‘scenario2’, // the function this scenario will execute
discardResponseBodies: false,
thresholds: {
// we can set different thresholds for the different scenarios because
// of the extra metric tags we set!
‘http_req_duration{test_type:api}’: [‘p(95)<250’, ‘p(99)<350’],
‘http_req_duration{test_type:website}’: [‘p(99)<500’],
http_req_duration: [{
threshold: ‘p(90) < 500’,
threshold: ‘p(95) < 900’,
abortOnFail: false,
  // we can reference the scenario names as well
  //'http_req_duration{scenario:my_api_test_2}': ['p(99)<300'],
export function setup () { //genarating token here
var url1 = ‘token genaration url’;
const payload1 = {
[“client_id”]: “13246546”,
[“client_secret”]:“466464646”,
const params1 = {
headers : {
‘Content-Type’: ‘application/x-www-form-urlencoded’,
‘Accept’ : ‘application/json’,
  tags: {
     name: 'Oauth', // first request
var Response1 = http.post(url1, payload1, params1, check);
// console.log(Response1.body);
// console.log(Response1.status);
// console.log(Response1);
check(url1, {
'is Auth ': (r) => Response1.status === 200,
let securityToken = findBetween(Response1.body, ‘“token”:"’, ‘",’);
return {securityToken};
//sleep(3600);
export default function (data) {
//console.log((data.securityToken));
let authToken = data.json(‘access_token’);
let refreshToken = findBetween(Response1.body, ‘“token”:"’, ‘",’);
console.log(refreshToken);
export function scenario1 (data) {
var url = ‘’;
const payload = ``;
const params = {
headers : {
‘Content-Type’ : ‘application/json’,
‘token = bearer token’ // using here
tags: {
   name: '231', // first request
//console.log(payload);
const Response = http.post(url, payload, params, check);
//console.log(Response.body);
//console.log(Response.status);
//console.log(globalThis.vars [“vuAuthToken”]);
check(url, {
'123456 ': (r) => Response.status === 200,
sleep(0.8)
var refreshed = 0;
export function scenario2 (data) {
if (diff > 4999) {
console.log(refresh the token)
var url = ‘scenario2’;
const payload = ;
const params = {
headers : {
‘Authorization’: Bearer token, // token using here
tags: {
name: ‘1313gdgd’, // first request
// console.log(Response.body);
// console.log(Response.status);
console.log(data.securityToken);
check(url, {
'134654 ': (r) => Response.status === 200,
sleep(0.8)
Thanks for opening a separate thread @Sreenivas, we’ll follow up on Generated Token every 10 mins and use it during load test.
Cheers!
